Gallien Krueger 800RB Discussion
Re: Gallien Krueger 800RB Discussion
Postby Ben Abraham on Tue Jun 05, 2012 3:34 pm
1009 wrote:
Ben Abraham wrote:
I'm confused. Are you using one GK head that's configured differently for bass and guitar or are you using two GK heads? Any particular reason you're running in biamped?
Just the one GK. I wanted to use the "high" out for guitar so that I could set the crossover frequency somewhere amenable to guitar tonez.
Interesting. Well I think you should be fine Bi-Amping it and running it out of the high speaker out, so long as the impedance is matching, I've done that before and it was fine. I think you can run 8ohm output to a 4ohm cab and be fine. But NOT a 4ohm output into a 8ohm cab. I think that's how it works, someone correct me if I'm wrong.
I'd be curious to hear how that set up sounds on guitar.
For the low output, I think it's 4ohms if you're using both outputs. I run my bass rig bi-amped and I run through the low out into a 8ohm 1x15 and it's been fine/
Michael Angelo Batio says "I'm going to give you the keys to the Lamborghini"
Ben Abraham
Postby 1009 on Tue Jun 05, 2012 3:36 pm
This is more or less what I was thinking.
At low volumes, it sounds great on guitar: very transparent to the TS-50's sound (the effects return is post-eq), and the crossover lets me brighten up the delta pro-thefuck I have in my 15. I can also add in some GK dirt with the boost, which might be a nice option.
I count to prime numbers and strum tonal clusters with Radiant Republic.
Bass in the Heavy Bombers We're on the PRF Singles Comp Q1.
Sax with Begin By Gathering Supplies.
I don't know what I did in Loex.
Postby Ben Abraham on Tue Jun 05, 2012 3:38 pm
Just edited my post to address your bass concerns.
Ben Abraham
Postby benadrian on Tue Jun 05, 2012 3:39 pm
Ben Abraham wrote:Interesting. Well I think you should be fine Bi-Amping it and running it out of the high speaker out, so long as the impedance is matching, I've done that before and it was fine. I think you can run 8ohm output to a 4ohm cab and be fine. But NOT a 4ohm output into a 8ohm cab. I think that's how it works, someone correct me if I'm wrong.
I think that's wrong. With solid state (SS) amps, the speaker impedance must be matching or higher than the amp's minimum impedance. On SS amps you will often see print by the speaker jacks that say "minimum load 4 ohms". That means you could use a 4 ohm cabinet, 8 ohm cabinet, 16 ohm cabinet, or anything else, as long as it's above 4 ohms.
As for the 100w high frequency amp on the 800RB NEVER go below 8 ohms. It has text that says minimum impedance 8 ohm, and they mean it. I've seen a number of blown up 100 watt sections on GK amps, and they are not easy to fix.
Postby Ben Abraham on Tue Jun 05, 2012 3:43 pm
Well if Ben Adrian says I'm wrong, I probably am. So listen to him.
On my bass rig, I have two 8ohm cabinets; I connect the high output into a 2x10 and the low output to the 1x15 and that's biamped. So far, nothing has a exploded.
Ben Abraham
Postby 1009 on Tue Jun 05, 2012 3:48 pm
Yeah, this is where I'm at. I like the bi-amped high (100w/8ohm) out when I'm playing guitar, and the full-amped low (300w/4ohm) when I'm playing bass. The deltra-pro is an 8ohm driver, so I think I'm ok in both scenarios.
Postby Eugenius on Tue Jun 05, 2012 3:49 pm
Ben Abraham wrote:Well if Ben Adrian says I'm wrong, I probably am. So listen to him.
Two 8ohm cabinets fits within the minimum parameters of the amp. If you were to use two 4ohm cabs you would have issues.
Eugenius
Postby Luzwei on Tue Jun 05, 2012 3:53 pm
CAUTION : Under no circumstances should the 100W and
300W outputs be connected together or to the same speaker!
This I have found here:
http://www.gallien-krueger.com/manuals/800rb.pdf
Does that mean that you shouldn't connect two separate speakers to two different outputs?
lemur68 wrote:A bite from a Lu Zworis is also highly venomous.
I Joe 4 play.
Luzwei
Postby 1009 on Tue Jun 05, 2012 3:54 pm
Definitely not!!! I'm only using one cab, and I'm switching the connection at the amp when I move from guitar to bass and vice-versa. Only one speaker cable!
Postby benadrian on Tue Jun 05, 2012 3:56 pm
That is totally safe.
8 ohm cab on the 8 ohm out of the highs. CHECK!
8 ohm cab on the min 4 ohm out of the lows. CHECK!
Hooray!
Postby Luzwei on Tue Jun 05, 2012 3:58 pm
Hooray!
or like we do it now:
tow 8 ohm speakers to out of the 4ohm out. right?
I Joe 4 play.
Luzwei
Postby benadrian on Tue Jun 05, 2012 3:59 pm
[quote="Luzwei"or like we do it now:
tow 8 ohm speakers to out of the 4ohm out. right?[/quote]
Yes.
Two 8 ohm speakers in parallel = 4 ohms. Totally safe.
Postby Luzwei on Tue Jun 05, 2012 4:07 pm
benadrian wrote:
Luzwei wrote:or like we do it now:
Yes.
We haven't really tried bi-amping. With our amp being so fragile I'm not so sure if we ever will.
I Joe 4 play.
Luzwei
Postby tontonp on Mon Jun 11, 2012 2:35 pm
I've a question about the bi-amp knob and the High 100 watts channel.
Does any sound go out of the 100 w channel when the bi-amp knob is not engaged?
In this case, will the ouput of the 100 watts channel be "full range"?
tontonp
viscount
viscount
Postby benadrian on Mon Jun 11, 2012 2:42 pm
tontonp wrote:I've a question about the bi-amp knob and the High 100 watts channel.
Yes. If the bi-amp is not engaged then you have a full range 300w power amp and a full range 100w power amp.
Postby tontonp on Mon Jun 11, 2012 2:56 pm
Thanx for the answer (Yeepie!).
tontonp
viscount
viscount
Postby Ben Abraham on Wed Jun 20, 2012 1:10 pm
So after owning my 800RB for the better part of a year, I only just found out how to get the thing to overdrive by cranking the input gain and boost. Don't I feel like a dumb.
Ben Abraham
Postby tallchris on Wed Jun 20, 2012 1:13 pm
Ben Abraham wrote:So after owning my 800RB for the better part of a year, I only just found out how to get the thing to overdrive by cranking the input gain and boost. Don't I feel like a dumb.
Oh yeah, the 400/800-RB actually has pretty damn good sounding solid state grit!
John W. wrote:I saw the best minds of my generation destroyed by Axl and Slash.
Band: http://policeteeth.bandcamp.com
tallchris
Postby benadrian on Wed Jun 20, 2012 1:38 pm
That's from the FET that's just after the boost circuit. The op amps sound like shit when they distort, but it's very hard to get them to clip. The FET is designed to distort pleasantly. Whomever designed the original 400/800RB preamp back in the early 80s did a great job.
Postby japmn on Wed Jun 20, 2012 4:41 pm
I've been seriously considering trying to trade my 75 Quad Reverb straight over for an 800RB and decent bass cab. I need a working, utilitarian, good sounding bass amp and do not need an over-sized cranky guitar amp.
Users browsing this forum: dontfeartheringo, Google [Bot], wjared and 8 guests
