Page 1 of 11
new turntable for me, please.
PostPosted: Sun Mar 02, 2008 8:56 pm
by jayryan
my old kenwood has decided (today) to start varying the play speed by itsself, irregularly, with some humorous results. i imagine that this is merely a belt issue, but my wife has suggested that we try to get a new turntable, so i turn to you, my more technically-oriented online comrades, to guide me.
1) most 'decent' turntables will be better than the 15 year old plastic kenwood i have.
2) i'd like to spend at the very most a couple hundred bucks - times are a bit tight right now.
3) i'd like some cool slab-looking thing which is way out of my price range.
who's got an extra sitting in their closet they want to sell?
PostPosted: Sun Mar 02, 2008 9:02 pm
by gjp
Nexxtech Lab1100
I have one of these. $99, sounds good, works well, no problems with it yet.
HERE.
PostPosted: Sun Mar 02, 2008 9:13 pm
by madlee
find a used one of these on craigslist
http://www.tnt-audio.com/sorgenti/techn ... 200_e.html
Re: new turntable for me, please.
PostPosted: Sun Mar 02, 2008 9:14 pm
by unsaved
jayryan wrote:i imagine that this is merely a belt issue
I'm no electronics expert, but one thing I do know is that belt-drives are CRAP. I have a Technics SL-DD22 direct-drive that is about 20 years old and still works just fine. Obviously they cost a bit more, but it's worth it.
PostPosted: Sun Mar 02, 2008 9:16 pm
by Sid Hartha
PostPosted: Sun Mar 02, 2008 9:28 pm
by TheMilford
+1 on the Project stuff.
Belt drives are NOT crap.
If you like to tinker you may have fun with an old AR-AX which can be found for cheap on Ebay.
PostPosted: Sun Mar 02, 2008 10:13 pm
by MF Nightmen
It's a little over what you want to spend, but Music Direct (in the west loop) has this champagne-colored Project table (with cartridge) on a closeout special for $329:
http://www.musicdirect.com/product/72054
PostPosted: Sun Mar 02, 2008 10:38 pm
by TheMilford
MF Nightmen wrote:It's a little over what you want to spend, but Music Direct (in the west loop) has this champagne-colored Project table (with cartridge) on a closeout special for $329:
this is a good deal.
save up the few extra bucks.
PostPosted: Sun Mar 02, 2008 10:56 pm
by amos
I have that project, It works/sounds good.
PostPosted: Sun Mar 02, 2008 11:10 pm
by LBx
madlee wrote:find a used one of these on craigslist
..seconded
PostPosted: Mon Mar 03, 2008 12:17 am
by caix
Music Hall. You will not be disappointed.
mmf 5
http://decibelchicago.stores.yahoo.net/ ... mf5tu.html
mmf 2
http://decibelchicago.stores.yahoo.net/ ... mf21t.html
Go with the 5, if you can afford it. Worth the money for the needle.
Those Projects sound ok. But honestly, the Music Halls blow them away. I had the opportunity to test these side-by-side in the store and the difference was startling.
Also, Decibel will have a ton of used stuff that will probably be in your price range. The guy's that run that place are nice and very helpful.
PostPosted: Mon Mar 03, 2008 2:10 am
by TheMilford
caix wrote:Those Projects sound ok. But honestly, the Music Halls blow them away. I had the opportunity to test these side-by-side in the store and the difference was startling.
FWIW they are both made in the same factory... there are some small differences from model to model. But over-all I found that they performed identicaly when comparing similarly priced models in the $200-$500 range
PostPosted: Mon Mar 03, 2008 2:17 am
by TheMilford
PostPosted: Mon Mar 03, 2008 2:30 am
by gjp
MrFood wrote:
yaphet wrote:Nexxtech Lab1100
Looks HIDEOUS.
Ok...?
Looks pretty standard to me.
PostPosted: Mon Mar 03, 2008 3:13 am
by steve
The best turntables have heavy platters and isolated motor mounts. The belt drive design further isolates the motor from the platter and is used in the very best turntables. There are expensive (Platine Verdier) and modest (Music Hall, Rega, Pro-Ject, VPI) versions of this concept. I can personally recommend the VPI Scout as a moderately-priced high quality turntable that offers the potential to upgrade every part if you start wanting to make incremental investments in improvement.
If you just want an inexpensive, reliable turntable, then the Technics Direct Drive DJ turntables work fine, have adjustable speed and are available cheap everywhere.
PostPosted: Mon Mar 03, 2008 3:27 am
by phildodd
I'm in the market for a new turntable too, right now it looks like I'm going to go for the Pro-Ject Debut III, I've read a lot of good stuff on the interwebs...
Edit: While we're on the subject of Pro-Ject, anyone used any of their little 'box II' things? I was thinking of getting the Phono, Pre and Power boxes to have as a small system that'll fit into my (probably tiny) bedroom next year...
PostPosted: Mon Mar 03, 2008 7:58 am
by caix
They're made in the same factory and they have the same tone arm. The stock needle that comes with the Project isn't all that great. The stock needle that comes with the Music Hall is pretty bad ass. Also, the Projects use a steel-cut platter that's pretty light. The Music Hall has a heavy glass platter.
Anyway, the difference really is major. Just because they're made in the same factory doesn't mean they sound close at all. Like I said, the only similarity between them is the tone arm.
PostPosted: Mon Mar 03, 2008 10:42 am
by enframed
+1.
i have a project "debut" that it 16 years old, it wasn't called "debut" at that point as i think it was the only model. still sounds fantastic.
they run about $300 still. sumiko is a fantastic company, too, very helpful.
my platter is very heavy. when i had the cartridge changed years ago the guys at a local high-end hi-fi shop (that sold linn and VPI) said that the platter was quite impressive for the price. perhaps they changed platters on later models.
PostPosted: Mon Mar 03, 2008 11:33 am
by Rog
I'd get a Music Hall. Maybe we should pool our resources and
buy some wholesale.
PostPosted: Mon Mar 03, 2008 11:40 am
by GrossOldWig
I recently replaced my cranky old ELAC with a Pro-ject Debut III (in sexy piano gloss black), and I love it. It's a very sleek, solid piece of hardware, and it sounds great. I would hug it, but I don't want to adjust the counterweight again.
If you get something cheaper, you'll probably regret it.
