speaker reconing Vs Replacement
Postby ianscanlon on Thu Jun 15, 2006 5:54 am
I have scored an ampeg B15T solid state portaflex.. but the speaker is blown.. the head works fine as I've used it myself powering several other cab's at our practice room, but the EV speaker is blown.. I've never had a speaker reconed.. is it worth it.. I guess the EV will be a a better speaker than say a £50 eminence driver that I could replace it with? Anyone got any recommendations.. I know there's a company in wembley that does recone speakers i've just always replaced old ones with new units before.
ianscanlon
red hodges
red hodges
Postby hiredgeek on Mon Jun 19, 2006 12:53 pm
i have almost always has the speaker reconed, especially if it something i like and want to keep original. read over this.
http://www.speakerrepair.com/OCSyes.html
they do great work, but a bit of a stretch for you..
myspace.com/trackandfieldrecording
http://www.myspace.com/monsonia
hiredgeek
boris badenov
boris badenov
Postby ianscanlon on Tue Jun 20, 2006 5:19 am
Thanks, we have a company in the old world that does this too! Which should at least save on postage.. but I think I will get the EV reconed in the ampeg combo.. seems like a good plan!
ianscanlon
red hodges
red hodges
Postby belta on Wed Jun 21, 2006 1:51 am
id go with reconing too, however, older speakers mounted in pressed steel (or other magnetic alloy) baskets become magnetized over time, and tend to lose their punch..... slightly
belta
piece of shit
piece of shit
Postby tzero on Sat Jul 22, 2006 7:29 pm
belta wrote:id go with reconing too, however, older speakers mounted in pressed steel (or other magnetic alloy) baskets become magnetized over time, and tend to lose their punch..... slightly
i was just going to ask about this topic. i bought an amp a long time ago with a similar situation. i took it to a place to have it fixed, and they said the speakers were blown. they fixed everything else, and i've held on the originals all this time. but i was wondering is it really worth it to recone them? even with the (slight) loss of punch? how would they compare to new speakers? at what point are they beyond saving, and should just be tossed?
any insight anyone has into this would be valuable...
tzero
envoy
envoy
Postby BadComrade on Sat Jul 22, 2006 7:36 pm
Jess Oliver, the man that designed the Portaflex, suggests this mod to all of the Portaflex amps:
"I do suggest a solid state rectifier, instead of a tube, which increases the power and reduces the heat. Another improvement is replacing the speaker with a Premium Quality speaker with an edge wound voice coil. This greatly increases the effective power. Using a 4-ohm speaker instead of an 8-ohm does much the same."
I'm thinking about doing it to the Portaflex SB-12 you see in my avatar.
Here's an interesting interview with Jess, from which the above quote was taken:
http://www.keithrosier.com/jess.asp
I played a drum in Tijuana Hercules.
Boombats wrote:I can't expect someone who plays an aluminum 12-string bass to have a sense of restraint.
BadComrade
Re: speaker reconing Vs Replacement
Postby Teacher's Pet on Wed Jan 24, 2018 12:44 pm
BUMP
I have a GK 4x10 bass cab from the 1990s. It has two blown speakers.
Not 100% sure if it's blown coils or what but I could probably figure that out.
Should I
1. repair them myself (never done this before)
2. send them somewhere for repair (Part Express doesn't offer this anymore?)
3. get new, better neodymium speakers like the guy on the phone at the audio place told me to do.
Help me out here.
Also, if anyone nearby wants to trade a 1x15" cab for a 4x10, holler at me.
Teacher's Pet
urinated in reservoir
Postby scrotescape on Wed Jan 24, 2018 2:31 pm
A guy in chicago john van L. Is good for repairs
Weber sells parts if you wNna try diy
scrotescape
padre
padre
Postby Anthony Flack on Wed Jan 24, 2018 11:06 pm
I've pulled out and reconed a speaker once before; it's not too difficult. That is to say, I managed to not screw it up.
Postby biscuitdough on Tue Jan 30, 2018 11:04 pm
Teacher's Pet wrote:BUMP
Should I
Help me out here.
Sending stuff out to be reconed is for expensive speakers like JBLs, alnico Celestions and Jensens.
Peavey speakers are designed to be reconed by non-professionals, but I don't think GK is the same.
Neodymium speakers are known to not handle distortion well, so if you use overdrive, I'd stick with the usual heavy ceramic ones.
If it's a ported cab I'd definitely buy the GK replacement. If it's one of the ones that used 32 ohm speakers in parallel instead of 8 ohms in series-parallel, same deal. If it's sealed and uses 8 ohm drivers you could throw in pretty much anything.
Users browsing this forum: No registered users and 11 guests
