Equipment: TC 2290
In: Intermittent input volume.
Out: to TC Electronics for total refurb.
Repaired:
Date: 7/01
Turns out, the input is routed through several normally closed contacts on isolated tin 1/4'' TRS connectors for loop send/return, parallel ins. Look at this shit.
The connections, most of them never used, oxidize and undermine the unit. Thankfully they aren't pricks about it, and will upgrade the box with gold plated connectors on the cheap.
Equipment: AKC CK1 capsule SN25063
In: ripped membrane
Out: to AKG
Repaired: $80 repair
Date: 7/01
Equipment: Sontec EQ
In: noise on return ch.
Out:
Repaired: recapped entire unit (electrolytic + tantalums), and replaced noisy 5534s
problem ended up being horrible discrete op ampsDate: 8/01
Equipment: UREI LA-12
In: 'auto' always on
Out:
Repaired: Found cold/intermitent solder joints on ratio/auto pot-switch. Re-soldered all pots and switches, moved link/dual switch from the rear to front face plate
Date: 8/01
