current DIY projects you are working on .. or planning on.
Re: current DIY projects you are working on .. or planning o
Postby numberthirty on Fri Mar 23, 2012 6:47 pm
Eugenius wrote:
benadrian wrote:I was working on a distortion pedal based on the IVP distortion circuit. I stopped because I got my current job.
He was hired to keep his IVP discoveries from reaching the world!
Somebody call Mulder and Scully.
Postby subprime on Fri Mar 23, 2012 6:48 pm
Get your priorities straight. Satisfying gear masturbators is more important than your job.
subprime
Postby numberthirty on Fri Mar 23, 2012 6:55 pm
subprime wrote:gear masturbators is more important than your job.
Would see.
Postby Eugenius on Fri Mar 23, 2012 6:57 pm
The Tone Is Out There!
Eugenius
Postby ldopa_chicago on Fri Mar 23, 2012 8:11 pm
Well played, sir.
I'm Bryan. It's good to meet you.
Postby benadrian on Sat Mar 24, 2012 4:25 pm
My job IS satisfying gear masturbators... Just a different demographic.
Postby Adam P on Sat Mar 24, 2012 7:46 pm
You guys with the sweet gigs...you guys hiring?
stu ungar
stu ungar
Postby japmn on Sat Mar 24, 2012 9:15 pm
Ok, I'm kind of having fun with this Bassman Project. I am still kind of new at schematic to Veroboard layout stuff, but here is my first go.
I'll probably put the little Tone Stack part on the same board with the larger board. I just have to find space. I want to keep it small as possible. Not sure I'm doing it as efficiently as possible, but it's a start. If you see anything wrong, let me know. I plan on trying this basic layout on breadboard before building.
Postby benadrian on Sun Mar 25, 2012 12:49 am
The pinouts on the J201 are not like the pinouts on the standard NPN transistor, so your J201s will have a twist in them if mounted up in that layout. I've still not had a chance to take a really solid look yet...
Postby japmn on Sun Mar 25, 2012 1:19 am
benadrian wrote:The pinouts on the J201 are not like the pinouts on the standard NPN transistor, so your J201s will have a twist in them if mounted up in that layout. I've still not had a chance to take a really solid look yet...
Shit, yer right. SHouldn't be too hard to fix, All I have to do is switch the strip for the source and the gate. I think that should do it though. Thanks for the heads up. I hadn't looked at the data sheet for the 201 yet.
I think this does it.
The components look stacked on top of each other a bit, but like I said, I like to keep it small. As long as it works. I'll probably try to jam the tone circuit in between where the caps and resistors for the first 2 gain stages are. The board will have a lot of cuts in it.
Postby Boombats on Sun Mar 25, 2012 1:51 am
It's a shitty cell phone pic but it's a dope guitar, made from random eBay parts.
The bridge is an excellent vibrato by Babicz
The work I have left is to rout the body to accept normal pickups (it's currently routed for those pups with one screw on one end, two on the other, which nobody seems to use anymore), throw the electronics in there and shred face. Fucker is light as fuck and sounds acoustically excellent.
...experiences deep shame when cross-posting in gear threads...
Postby galanter on Sun Mar 25, 2012 2:56 am
Working on my most ambitious physical computing project so far. Tonight I got SD card reading/writing working. Tomorrow I start on the XBee data radios.
galanter
Location: Yes, the avatar really is an actual picture of me.
Postby Rodabod on Mon Mar 26, 2012 4:03 am
benadrian wrote:The miller effect is a great pointer. Some kind of first order LPF starting at about 8-10kHz would add a bit to this design.
Yeah, that 0.1nF cap should do something like that. Suck it and see.
Also, scrub that 33K resistor at the input if you want. That was doing the job of controlling HF response in the original design and doesn't work the same here which is why I suggested adding that cap instead.
Postby motorbike guy on Mon Mar 26, 2012 7:40 pm
Boombats wrote:Image
dude, you know I love you and everything, but that guitar offends me. it is hideous. anyone playing that guitar will not be taken seriously by me.
sorry.
jimmy two hands wrote:90% of everything is bullshit.
Postby japmn on Mon Mar 26, 2012 7:41 pm
sorry.
I think it's zingy! You should spray paint it gold.
Postby numberthirty on Mon Mar 26, 2012 7:44 pm
motorbike guy wrote:dude, you know I love you and everything, but that guitar offends me. it is hideous. anyone playing that guitar will not be taken seriously by me.
sorry.
Being taken seriously is way overrated.
Also, I can't take you seriously if you won't capitalize.
Postby endofanera on Mon Mar 26, 2012 9:27 pm
sorry.
The entire forum spends years going apeshit over barely playable crappy mid-60s Japanese department store guitars with nary a mention or eyebrow raised, but this guitar offends?
Ah, fashion.
Postby subprime on Mon Mar 26, 2012 9:31 pm
Its the points. theyre just so. ugh.
subprime
Postby Boombats on Mon Mar 26, 2012 11:19 pm
Cringe all you will, but this thing sounds awesome and sits well on the lap. Strapped, it is a war sword. Kiss my metal.
Postby Boombats on Tue Mar 27, 2012 5:23 pm
Oh and I just wrote a really pretty, almost "indie" sounding song on it.
Users browsing this forum: Bing [Bot] and 3 guests
