Solid State Amps
Re: Solid State Amps
Postby Adam P on Sat May 12, 2012 12:15 pm
Does plugging a cab into the extension cab jack cut the signal to the internal speaker in the combo? Can you post a picture of the inside that shows the extension speaker jack as well as the wires to the internal speaker?
I'd guess the extension jack just has a normally closed contact on the tip that passes the signal through to the speaker and is opened when you insert a speaker cable into the jack, breaking the connection to the internal speaker.
"amarillo slim" preston
Postby subprime on Sat May 12, 2012 12:21 pm
Yeah I figured that. I assumed I was worrying about nothing.
subprime
Postby subprime on Sat May 12, 2012 12:24 pm
Would it be possible to mod this to add some sort of gain stage to it to let it distort a bit more naturally. I actually care about the speaker its running into now so I dont want to get the power amp distorting like I did before (I think? I would turn it to 11 then run a gain boost into it)
subprime
Postby Adam P on Sat May 12, 2012 12:25 pm
Yep. That should work just fine (the speaker).
Postby subprime on Sat May 12, 2012 12:54 pm
The form factor of this thing is really fucked up, the front is shorter than the back by a good bit. I might be able to bend the metal into an easier to work with shape, but I doubt it.
subprime
Postby SR-1 on Mon May 14, 2012 1:43 am
Is there any reason for me not to buy a Vox Pathfinder 15R? I'm trying to find a downside. Can I get noisy, annoying, squawky feedback from an amp of that stature without jamming the guitar right in the speaker?
SR-1
tmidgett
tmidgett
Postby SecondEdition on Mon May 14, 2012 9:24 am
SR-1 wrote:Is there any reason for me not to buy a Vox Pathfinder 15R? I'm trying to find a downside. Can I get noisy, annoying, squawky feedback from an amp of that stature without jamming the guitar right in the speaker?
I have a lot of trouble making the thing feedback at all.
Life...life...I know it's got its ups and downs.
The Captain of the Gravy Train.
Horse_ebooks wrote:There is no form or method. There is only emotion.
Pink City.
SecondEdition
Postby numberthirty on Mon May 14, 2012 6:56 pm
From an old Adrian Belew article -
You need a compressor pedal and a graphic eq pedal.
Postby 6079smith on Tue Jun 26, 2012 7:18 pm
Seems like the best place to put it... anyone know the Univox U200L? All I can find about it is 'real loud Fender Twin clean' and it has four variable outputs, and I'm thinking about it seeing as there is a guy aound the corner selling one for about $80.
6079smith
Postby zom-zom on Wed Jun 27, 2012 7:23 am
6079smith wrote:Seems like the best place to put it... anyone know the Univox U200L? All I can find about it is 'real loud Fender Twin clean' and it has four variable outputs, and I'm thinking about it seeing as there is a guy aound the corner selling one for about $80.
I did a quick search and found some photos and basic info. Supposed to be 210 watts, same output power for any impedance. The build looks very good, photos of the inside show a very good layout and the construction looks nice. For $80 I think it would be worth it if it looks good. I have a Univox ULM6 tube combo from the '70s, like a Champ with two tubes and a 10" speaker and it's really nice.
http://www.univox.org/
zom-zom
Postby 6079smith on Thu Jun 28, 2012 2:25 pm
Yeah, information about it is a bit sparse, most of the reviews/descriptions seem to be written by the same guy. I did find a schematic though... solid state amp with an output transformer? Interesting. I wish the guy would get back to me already...
6079smith
Postby Evanc521 on Wed Sep 26, 2012 11:38 pm
My Ampeg SS150 head just died. The power amp in still works but the preamp isn't working... the led's don't switch between channels. Any ideas? I'm thinking a cold solder joint?
Evanc521
tunnel
tunnel
Postby brephophagist on Thu Sep 27, 2012 12:30 am
Teacher's Pet wrote:
benadrian wrote:I've actually though about writing a book. It would be something like "Understanding your gear: explaining musical electronics for the diy/curious musician."
Would buy. Please post Kickstarter link.
+1
geiginni wrote:Not to be confused with the "Glass Buttplug Healing Club"
brephophagist
paul schaffer
paul schaffer
Postby Verbs & Nouns on Fri Sep 28, 2012 4:53 am
WoundedFoot wrote:
Adam P wrote:Sunn Beta if you can find one
Yes. Also, any 70's model Acoustic. I swear by them both for loudness, clarity and power. TONE.
+1
I have an Acoustic 470 that I used to run through two 4x10's. Thing was crushingly loud. Had a guitar and bass switch. It switched to guitar with my Kramer bass made it sound like breaking glass. Indestructible as well.
Verbs & Nouns
secretary of the interior
Postby warandhairstyle on Fri Sep 28, 2012 10:51 am
+1
+1 more to this whole fucking thing. I use an Acoustic 450, 470, 270 and a Sunn Coliseum. Old Acoustics are a mind boggling value.
warandhairstyle
novitiate
novitiate
Postby deadfate on Sat Sep 29, 2012 5:26 am
What is a good SSamp to join a Traynor YGL-3A? I need some aggressive distortion, in between early SWANS, Heroine Sheiks and Unsane punchy toan (luzwei knows). I run the traynor on a earcandy buzzbomb, use a rat or a ds1 and a tele. I have a Yamaha g100, as poster before, but it's really too heavy! I will run the SS amp on a tl606 that I will made. Let's the brainstorm begin!
deadfate
les miserables
les miserables
Postby Luzwei on Sat Sep 29, 2012 8:29 am
This is the greatest SS amp I have tried and first one in EU is mine. Dibs, deadfate, DIBS!!!
lemur68 wrote:A bite from a Lu Zworis is also highly venomous.
I Joe 4 play.
Luzwei
Postby meatpuppet on Sat Sep 29, 2012 8:37 am
Luzwei wrote:This is the greatest SS amp I have tried and first one in EU is mine. Dibs, deadfate, DIBS!!!
Explain Croat
meatpuppet
bert
bert
Postby Luzwei on Sat Sep 29, 2012 8:43 am
Explain Croat
Back off!!! Should I CAPS LOCK it???
I Joe 4 play.
Luzwei
Postby godcity on Sat Sep 29, 2012 9:06 am
i've got one of these. it's neat and totally weird.
http://www.ebay.com/itm/CMI-ELECTRONICS ... 2eb4b2a203
godcity
convert
convert
Users browsing this forum: Bing [Bot] and 10 guests
