Seeking advice for aluminum bolt-on neck build/set-up
Postby uglysound on Thu Jan 26, 2017 4:04 pm
I am going be getting a couple of EGC necks; a used one with a square heel, and one from the batch that Kevin is working on right now with a round heel.
Is it recommended to have someone that knows what they are doing bolt everything together, or can I safely do this before having a tech do the final setup? I have never built a partscaster of any kind. I am very comfortable with electronics, but that doesn't give me a playable guitar.
Has anyone tried one of those backbone resonance enhancers? I'm curious if it would be worth trying, or if they are snake oil? The demo videos I've seen tell me nothing.
Thoughts, advice, criticisms, and opinions on my upbringing are welcome.
uglysound
pauly shore
pauly shore
Re: Seeking advice for aluminum bolt-on neck build/set-up
Postby uglysound on Fri Jan 27, 2017 6:22 pm
I sent Kevin a message asking about set up, and this was his response:
"Its easy to do yourself. They have machine screws. I can walk you through the set up. Its so easy that there is no need to pay someone to intonate your guitar."
I'm very excited to build these guitars! I had no intention of getting two necks, but as I was going back and forth about the one I am trading for, Kevin posted a message on FB about building a batch of them, so I pulled the trigger on one. I assume this is why so many people have more than one EGC guitar. Put a deposit on your dream build, and an awesome EGC shows up on here or Reverb during the wait.
uglysound
pauly shore
pauly shore
Postby uglysound on Fri Jan 27, 2017 6:37 pm
As for these things...
For some reason, I thought they were $35-45, but now I see they are $60-70! I seems like an ok idea, but I can't see it making much of a difference. Plus, at that price, it is in the "worth doing it yourself" territory (if it's worth using at all).
I have to admit I know little about natural acoustics and resonance, so maybe it's cooler than I think?
uglysound
pauly shore
pauly shore
Postby weezy on Fri Jan 27, 2017 6:47 pm
I don't do BookFace or anything, so was he selling any bass necks?
lt. kara 'starbuck' trace
Postby uglysound on Fri Jan 27, 2017 7:00 pm
Bass and guitar, yes. No baritones.
I have a "zero friend" FB account. Mostly to have an online presence for Uglysound Electronics, but also to follow bands and other stuff I'm interested in.
uglysound
pauly shore
pauly shore
Postby weezy on Fri Jan 27, 2017 7:53 pm
Do you mind putting a link here? I am not joining FuckFace and don't ever want to.
Postby eliya on Sat Jan 28, 2017 12:10 am
I meant to reply, but yes, if they're bolt-on the same way Fender are, then it's a matter of putting the neck in the neck pocket and putting the screws through. That's about it.
Postby uglysound on Sat Jan 28, 2017 12:29 pm
weezy wrote:Do you mind putting a link here? I am not joining FuckFace and don't ever want to.
Kevin posted a note in the aluminum axes group, which will not load if you are not a member. I think they sold out pretty quickly, but you could always email or call to see what's available.
uglysound
pauly shore
pauly shore
Postby four_oclocker_2 on Sun Jan 29, 2017 11:59 pm
Also very stoked about this. I have one on order for my JM right now. If he does another run and I dig this one, I might grab one for my P-bass down the line. Can't wait to see how they turn out!
Unofficial Pono spokesperson.
SELF/KJ/SAR/BP
SUMMER OF DOUG'S
four_oclocker_2
Postby Raa on Tue Jan 31, 2017 4:46 am
Are you using a ready made body? Then its just like Eliya says. I did it and I'm hopeless with stuff like that. Judging by your incredible eurorack builds you've got this easy.
Raa
duke ellington
duke ellington
Postby bassdriver on Tue Jan 31, 2017 6:39 am
I bought FM Scott's EGC neck and made this:
all parts from Warmoth Custom Guitar. it's as simple as just putting it together. plays and sounds fantastic!
Postby uglysound on Tue Jan 31, 2017 7:04 pm
From FB:
There have been a lot of folks wanting these so, if you want one email me by Thursday afternoon and Ill get more metal on the way. sales at electrical guitar company dot com. This run is shaping up to be between 20-25.
uglysound
pauly shore
pauly shore
Postby weezy on Tue Jan 31, 2017 7:48 pm
^ thanks!
Postby landspeednyc on Tue Jan 31, 2017 8:11 pm
(Partially off-topic) For those on FB but not in the Aluminum Axes group, it's been pretty active recently- Kevin announcing the run of necks, NAMM coverage, links to used Beans, people receiving their Obstructures builds, etc. Worth checking out.
This video was posted today:
Aluminum Neck Guitars with Kevin Burkett of EGC and Marc McElwee of Travis Bean at NAMM 2017
landspeednyc
sweeny todd
sweeny todd
Postby landspeednyc on Wed Feb 01, 2017 8:10 pm
Instagram post on necks:
https://www.instagram.com/p/BP_WDzulK8K/
We have been asked for years to make a run of bolt on necks, we are finally doing so. All necks will be 25.5 scale with round or square heel. We will be making a bass neck as well, 34.00 scale with round standard heel. Guitar bolt on necks are 750.00usd with tuners and nut. Bass bolt ons will be 800.00 with tuners and nut. Email us if you'd like to get one, sales at electrical guitar company dot com
landspeednyc
sweeny todd
sweeny todd
Postby terminalgs on Thu Feb 02, 2017 4:53 pm
It isn't hard, but the dimensions of the body and bridge type are important factors to get the action you want. Different bodies have different depth heel pockets, and that will decide how high or low the neck sits in relation to your guitar body. plus you want make sure it all goes together such that the bridge string height is adjustable up or down (you don't want the height screws at their highest travel nor at their lowest.
what kind of guitar body are you planning to use?
terminalgs
comrade
comrade
Postby uglysound on Thu Feb 02, 2017 6:34 pm
terminalgs wrote:what kind of guitar body are you planning to use?
I was thinking this one for the square heel neck:
The round heel neck will probably not be built in the near future. When I do, it will probably be a jazzmaster, especially after seeing FM bassmaster's beautiful example above! Although it would be fun to try to get a hold of one of those aluminum strat bodies, and build that.
uglysound
pauly shore
pauly shore
Postby terminalgs on Thu Feb 02, 2017 11:27 pm
you are probably okay. the tele has a flat body, and so long as the neck pocket is square to the body top, you are probably okay. if the floor of the neck pocket isn't square (i.e. parallel to the plane of the top of the guitar), your neck could tilt up or down which would blow the action. Remedies can be as simple as a card shim in the neck pocket (fore or aft), or routing the slightest shave off the floor of the neck pocket square to the body.
Put it all to together, if you can't get the action right, turn your attention to sorting out the neck pocket.
terminalgs
comrade
comrade
Postby weezy on Fri Feb 03, 2017 8:04 pm
Anybody else get on the bandwagon? Put down my deposit, now to figure out what to put this neck on that wouldn't be too disgraceful, or so disgraceful it works.
Postby codetocontra on Sun Feb 12, 2017 1:19 am
I am in on a bolt-on too. Have a locally made Tele body that I am pretty excited about, made from reclaimed wood taken from the floorboards in a 1912 house. Ordered a Backbone as well, complete imitation of the real deal but seems proper for this build.
codetocontra
hemingway
hemingway
Users browsing this forum: A Landing Craft, yard barf and 11 guests
