Welding Cable xlr GEFELL MV692
Moderator: Electrical-Staff
Postby melvins111 on Fri Apr 27, 2012 2:41 am
Hello all.
I just got a microphone geffel mv692.
I have and its transformer connectors.
However, I miss a NS104 via XLR cable.
With it, how to proceed with welding?
Thank you for your help
melvins111
adjutant
adjutant
Re: Welding Cable xlr GEFELL MV692
Postby melvins111 on Sun Apr 29, 2012 3:37 am
hello.
nobody could help me, I find it on the net
thank you
melvins111
adjutant
adjutant
Postby melvins111 on Mon Apr 30, 2012 5:13 am
hello,
I can not test the microphone if I did not connect a cable xlr.
Or find plans (schematics) for welding this one.
thank you again
melvins111
adjutant
adjutant
Postby greg on Mon Apr 30, 2012 4:24 pm
I'm a little unsure what you're asking, but I assume you are trying to build an adaptor to connect the original connector to a standard XLR. I googled "Gefell MV692 Schematic" and found this page. Both sets of schematics are there. It looks like you will have to do more than make an adaptor cable. There might be additional internal modifications. I recommend contacting Gefell directly to get the proper upgrade. They still support this mic.
Good luck,
Greg
greg
Postby tarandfeathers on Thu May 03, 2012 1:31 am
Agreed. I had my 692 48 volted/XLRed by MTG a few years ago, couldn't be happier.
Don't shun it. Fun it.
tarandfeathers
Postby melvins111 on Thu May 03, 2012 3:09 am
thank you greg
it's not that.
Just how the welded wire
melvins111
adjutant
adjutant
Postby greg on Thu May 03, 2012 3:04 pm
I'm Confused then,
Please ask your question en français. Our international department (Gregoire) will help you.
greg
Postby melvins111 on Fri May 04, 2012 6:55 am
ok
je possède pour ce microphone le transformateur et le câble qui le relie.
il me manque l'autre cable qui se termine en xlr.
IL faudrais que je fabrique le cable qui relie le xlr. avec ceci que je possède:
http://cgi.ebay.fr/36-VEB-MIKROTECH-GEF ... 20c45a9723
je voudrais le souder et pas faire n'importe quoi.
je ne trouve pas de schéma sur le net.
Merci a tous
melvins111
adjutant
adjutant
Postby gregoire on Fri May 04, 2012 11:27 am
Salut melvins111, si je comprends bien tu as le micro, le boitier d'alimentation, et le cable qui relie le micro au boitier d'alimentation. Il te manque donc le cable qui relie le boitier d'alimentation au XLR. C'est ça?
Dis moi si c'est ça et je vais traduire ton problème pour que les gens du forum puissent t'aider, merci et à bientôt!
Grégoire
gregoire
mother superior
mother superior
Postby melvins111 on Fri May 04, 2012 2:25 pm
bingo, c'est exactement ça
il faudrais quer je sache comment souder le câble qu'il me manque.
Ps: desoler pour le non anglais et surtout grand merci a vous
melvins111
adjutant
adjutant
Postby gregoire on Fri May 04, 2012 3:58 pm
melvins111 wrote:ok
Merci a tous
OK, so melvins111 has a MV692 with a power supply. He has the cable to connect the mic to the power supply and he is looking for a wiring diagram to make a cable from the power supply to an XLR connector. In order to do that, he has already bought a 7-pin connector that connects to the power supply.
Here are two things that I found online:
N692 manual
48V adapter wiring diagram (look at the very bottom of the page)
Greg Norman recommends that you contact Microtech Geffel directly so they can explain to you how to do that. Any help is appreciated!
PS: si tu as du mal à comprendre ma réponse en anglais tu peux m'envoyer un message perso en francais, à plus!
gregoire
mother superior
mother superior
Postby Nate Dort on Mon May 07, 2012 1:14 pm
greg wrote:I'm Confused then,
In a surprising turn of events, Greg is the first to surrender.
Nate Dort
not wearing any pants
Postby greg on Mon May 07, 2012 2:17 pm
Actually,
Gregoire is acting as my avatar in this case. In a way, I am occupying him like the Nazis.
I should add, that the 48v mod is not the ideal way to go about using this mic. It will make sound, but probably have less current to work with than spec'ed for "T phantom" (which, only glancing I think it is). If he wants to use it with 48v phantom power, he should have Gefell mod the mic for him. Otherwise, he needs to find out which of the several output wiring schematics is right for him. So we need a German avatar now...
greg
Postby melvins111 on Tue May 15, 2012 2:35 am
I still did not test the microphone.
I find nothing on the internet.
here is a picture of the whole.
GEFELL MV692
GEFELL MV692.jpg (199.84 KiB) Viewed 1240 times
How to solder the two connectors under the arrow?
melvins111
adjutant
adjutant
Postby greg on Tue May 15, 2012 3:15 pm
Contact Microtech Gefell
http://www.microtechgefell.de/index.php ... etzgeraete
Click on Questions, and ask them...
Or do it on this page.
http://www.microtechgefell.de/index.php ... forms&id=1
Sorry I couldn't have been more help to you.
greg
Postby gregoire on Tue May 29, 2012 10:09 am
Ok, so I had emailed Microtech Gefell about that a few weeks ago, and they responded today with the solution. Here is the drawing you need:
Let us know if it works!
Gregoire
gregoire
mother superior
mother superior
Users browsing this forum: No registered users and 0 guests
