Wall box 24 XLR sutio help
Postby melvins111 on Thu Dec 29, 2016 9:22 am
Hello everyone,
I am french
I am looking for a 24 XLR wall box to install in the studio. With multipaires.
I do not know much but I am looking for a good quality with a budget of 300 euros max.
Advise you to mount it yourself or take it whole?
Thank you for your answers
melvins111
duke
duke
Re: Wall box 24 XLR sutio help
Postby bishopdante on Thu Mar 02, 2017 5:40 am
Canford aren't the cheapest, but then again, considering the effort of installing and soldering up a wall-box, it's a trivial cost to use the proper parts (do not want plastic sockets, crimped connectors, spending hours hunting for faults/buzzes/interference etc... not worth it).
________
Chassis:
Flush mount:
http://www.canford.co.uk/Index/Modular- ... ng-modular
Surface mount:
_____
You might want 32 holes rather than 24 so you could also add a couple of TRS jack monitor/headphone sends, and a couple of XLR returns.
Would highly recommend at least one ethernet network socket, possibly even HDMI/VGA/USB, or even fiber optic (for ADAT or similar) or DIN (for MIDI).
Same price for 32x holes as 24x.
Can just block up any surplus with blanking plates, and save them for later.
_______
Audio Connectors:
Neutrik XLR metal body: http://www.canford.co.uk/NEUTRIK-XLR-PA ... D-L-series
Jack: http://www.canford.co.uk/Products/43-27 ... CKET-Panel
_____
Other types that might be useful to have on the wall:
Speakon (for running a speaker cabinet with the amp head in the control room, or a talkback / monitor speaker) http://www.canford.co.uk/Products/22728 ... -connector
RJ45 Ethernet:http://www.canford.co.uk/XLR-connectors/SWITCHCRAFT-UNIVERSAL-SERIES-CAT5E-AND-CAT6-RJ45-CONNECTORS
USB: http://www.canford.co.uk/XLR-connectors ... CONNECTORS
TOSlink: https://www.amazon.co.uk/kenable-Optica ... B007OH6PIS
Code: Select all
01100011 01101111 01101110 01100111 01110010 01100001 01110100 01110101 01101100 01100001 01110100 01101001 01101111 01101110 01110011
bishopdante
Postby Adam P on Sun Mar 19, 2017 8:31 am
At your budget I'd probably be looking to buy the materials and build it myself, or buy used if possible. The materials aren't that expensive (depending on how long of a run the multi pair needs to be) but it's fairly labor intensive, which is what you'll be paying for.
Adam P
suspicious flashlight
Users browsing this forum: No registered users and 1 guest
