Postby greg on Thu Feb 21, 2019 6:05 pm
thecr4ne wrote:Hey Greg, do you guys use the 4665 Transformers in the Altec 525A psus for the 175s? Thoughts on this vs. going without them?
We did have one transformerless supply, but I put one in so they'd be all the same.
I think it sounded fine without it, but can't remember.
Beyerdynamic M500 -
Loose part inside.
The diffuser/filter assembly fell off the ribbon magnet. Glued it back on, and replaced the decomposing foam in the windscreen.
Schoeps 221b -
Broken capsule pin on the amp.
Replaced with a springed gold probe pin.
Postby greg on Thu Feb 28, 2019 10:05 pm
Neotek Elite-
Cleaned some dirty switches.
Channel 5 Aux AB always sending to A.
I pressed the ground leg on the offending stack, and the problem disappeared. I suspect it's the same as some of the other pots in that the rivet securing the leg to the pot's pcb (or wafer) is losing connection. I tried a number of different pressure points, and the problem didn't come back. It will eventually. Unfortunately, you have to desolder the entire row of aux switches to get this one out. If it comes to it, I might disassemble the pot, in circuit, and do whatever work I can that way.
Schoeps 221b-
No output.
DEAD AC701! The grid is internally shorted to the cathode. A smarter person than me said the mic was probably roughly handled. It doesn't happen electrically. So, I guess let that be a lesson for everyone. Treat like crystal!
-Elsewhere NY-
Neotek Series II
Cleaned a bunch of faders, fixed some channels, some by reflowing some broken solder joints on the channel headers, replaced some pots...
Lexicon Prime Time delay-
Delay would work for a few seconds after power up then go quiet, while the display looked the same (though no input metering).
5v regulator was making bad contact with the socket it was sitting in. I cleaned it all out, and bent the to220 legs towards the pins in the receptacle. Worked the rest of the day. Their plan is to recap the main board, so I recommended to them that they solder the regulator directly to the board later.
AKG BX20-
Noisy Channel 1
One of the fairchild dual op amps was oscillating. All the components around it measured correctly, and the oscillation occurred if the channel PCB was in either socket. They plan to recap and replace the amp when they get parts.
Slappy delay sound on Channel 2
One of the "record" coils measured open when the DC resistance should have been under 300Ω. The fault description in the manual was consistent with what we were hearing too.
They're ordering a new one from a guy in Germany
Otari MTR 90 CB120 Remote-
Display and functions freak out when buttons are pressed hard.
Discovered I could reproduce the problem by wiggling a four pin cable connector on the board with the buttons (on top of the display board). I cleaned and checked the tension on the female socket pins, but the problem could still be there with some force.
This cable went to a 5v switching regulator module. The four wires were in two pairs, high voltage-0v send, and 5v-0v return. The two 0v conductors were tied together at the regulator, but not on the pcb. I tried jumpering them together at the pcb header, and the problem never came back.
Cleared up some other ground and power distribution issues.
Postby thecr4ne on Sat Mar 16, 2019 11:15 am
Hey Greg,
RE: altec 525A
1:When replacing the selenium rectifier, did you just put in 4 diodes in a bridge configuration? I have one of these that just has 2 diodes soldered onto the old rectifier, wondering if this is sufficient.
2:Do you also put a new diode in place of Rect.2? should this be left half wave or bridged?
Thanks
greg wrote:Altec 175 dead
[color=#004000]
Altec 525a power supplies-
Replacing selenium rectifiers with modern diodes, and figuring out the right value for a voltage drop resistor for the B+.
I discovered, while testing the above mic that a couple of our supplies were providing only 4 volts to the filament. Replacing the selenium fullwave rectifier with silicon diodes brought that up to 6-6.3 volts. The B+ was way to high with the new diode. I have to add a series resistor to it to bring it down. Working on the best value to get the voltages specified in the schematic.
More later.
thecr4ne
Postby greg on Thu Mar 21, 2019 11:21 am
Neotek Elite Channels
Channel ?
Intermittent switches in the signal path cutting out, or distorting the signal in various modes.
I previously hit the suspect switches with an alcohol cleanse, exercise, then stabilant routine (via syringe). This had mixed results, probably due to the fact that the dirt can't escape, so it took it to the next level. I pulled the channel and took apart the switches. This way, I was able to scrub the parts individually with q-tips and apply the conductive lube in a clean way. I lost 3 of the 36 contact tension springs in the process (about 1 x 3mm in size), but had some spares to steal from. It's a little tricky to get them in there. A slight misjudgment sends the spring 15 feet off into oblivion (as far as my eyesight is concerned). I found my rhythm using a tiny flathead screwdriver (flathead wedged between the last turns of the spring, pressed the other end into the back of the wiper piece, compress and twist into place, drawing out the screwdriver with my finger holding the spring in place). This all took more time that I hoped. The faceplate had to come off and there were some stubborn nuts to remove.
This problem is becoming more frequent. It would certainly be quicker to replace the switches. I'll wait to see if this channel gives us any more grief.
Installed in Channel 2 position now.
Channel 2-
Pad and Phantom power switches intermittent.
Pulled. It's worth noting that the microphone signal goes through the phantom power switch (as opposed to the switch just handling the 48 volts). It's just as important for it to be perfectly working as the pad switch.
Replaced the switches with a pair of new gold contact versions. This took 5 minutes to do, mainly because they can be removed without taking the faceplate off.
Postby greg on Thu Mar 21, 2019 11:36 am
RE: altec 525A
Just replace the selenium rectifier with two diodes (as it appears in the schematic). It's not meant to be a bridge. The old rectifier should be completely out of the circuit if you do. It sounds like yours might have two new diodes in parallel with the old?
We have converted a few supplies to use a regulator circuit for the filament. In that case, a bridge rectifier is good for getting the most out of that transformer winding.
It should be left half wave as it is in the schematic.
Postby thecr4ne on Fri Mar 22, 2019 12:21 pm
Awesome, Thanks Greg.
Yes, mine has the diodes paralleled to the old rectifier, just soldered to it's terminals. I have 5 of these I'm trying to recap and standardize, figured I'd update the rectifiers along the way.
I finally got a 29B capsule, but it looks like its' got some crud in the screen around the base. I've seen some posts indicating you've cleaned these before, and even taken some apart. Do you have any advise for taking care of this?
Thanks again. I really appreciate the help.
thecr4ne
Postby greg on Tue Mar 26, 2019 12:55 pm
Not sure exactly where you're talking about as far as dirt goes, but in general, be extremely careful. Don't use compressed air to blow things out. Particles could end up where you don't want them (wedged between the diaphragm and back plate, for instance).
Postby greg on Tue Apr 23, 2019 5:24 pm
RCA 74 Jr Velocity-
No output, ribbon in good condition.
Primary measuring a short (roughly .2Ω)
Part of the original insulator on one of the primaries split in a hidden spot. Covered it all in heat shrink. Back in business.
Altec 436c-
No audio getting through...
Hi voltage secondary is on the power transformer is dead, as is the selinium rectifier.
Replaced the original power supply caps, and power cable. Cleaning up some other wiring.
Ordered new transformer.
Postby greg on Thu May 09, 2019 3:28 pm
-Elsewhere-
EMI TG12345 MKII/III 24+ channel 8 bus console.
Random sputtering noise on the outputs, annoyingly intermittent (once every few hours annoying).
The channels are made up of multiple PCBs tied together by solid wire jumpers. Some of these have oxidized, degrading their solder joints, causing this kind of noise. Also, a number of electrolytic capacitors have been bulging, and falling out of spec (50ish years old). In the past, one of the cassette power supplies was causing a similar noise all over both the channels in the cassette. The problem was traced back to a failed electrolytic cap.
The decision was made to replace the electrolytics , and reflow all the board to board solder joints, replacing any really oxidized jumpers. I cleaned some other hard to get at switches and connections while I was at it.
So far, the console has been quieter.
Postby steve on Sun May 12, 2019 3:25 pm
I've read about the potential for oxidized leads to make a semiconducting junction with connector contacts, like a cat's whisker or a diode, do you think that's what happens inside the solder joint or the solder joint breaks and becomes intermittent?
Postby dearatanha on Wed May 22, 2019 12:03 pm
Hey Greg!
I love all the tech talk and information that is shared here. Inspiring and generous. I’m brand new to the forum and glad to be here.
We are having troubles with our Furman HD6 system at our studio. Do you by chance have the PDF drawn up for your modifications? You had mentioned it in your post (from many years ago) If that is handy, I might try my hand at that for our team :)
Also, did you have any other non belden 10core cables that you may have considered? That cable is only available in 1000ft rolls ;)
Cheers and thanks!
Eric
dearatanha
Postby greg on Wed May 29, 2019 9:46 pm
Hey Eric,
You referring to this?
viewtopic.php?p=1401195#p1401195
After years of experience with our past and current setup, I've concluded that you're better off dedicating several stands for the furman mixers and wiring as-is, then zip tying the cables to the stands to strain relieve the connections. This worked in my studio, and is a lot less of a pain than refitting the old boxes. Our new wiring is nice, but it cost quite a bit in parts and labor. We still have more issues than I'd like, because of the density in the small connectors and abuse.
A bag of heavy duty zip ties, and broken cymbal stands is much more efficient. I'd twist the grey and blue wires together as a pair, so it's tidy too.
dearatanha wrote:Hey Greg!
Cheers and thanks!
Eric
Postby greg on Tue Jun 04, 2019 2:53 pm
Various tech chores mentioned before.
Hafler P500 -
Right channel intermittently cutting out after several hours of use.
After probing around, I could cause a failure by wiggling the Mono/Stereo switch. I decided to hard wire it to stereo mode since that's the only application we'll use it for (clearly labeled now). The contacts of the open frame switch were blackened with oxidization. I exercised a bunch of connections and cleaned out some of the grime while in there.
Working properly after a few days of abuse.
Altec 436 (both) -
Different problems with each compressor, not related to tubes. These were modified in the 90s by someone to add attack, and release time adjustments, and an output attenuator. On both, there were old carbon power resistors meausring 1/2 their marked value in the power supply (R14).
In general, neither is behaving predictably or properly.
Rebuilding both. One to a popular mod (NY Dave's design), the other to a EMI RS124. I'll let you know if they work years from now.
Postby greg on Fri Jun 07, 2019 4:31 pm
Fender Deluxe (modified 5C3 using a 12ax7 and 12ay7) -
Motorboating oscillation when the "mic" volume was all the way down, guitar connected to the "instrument" input (like normal). Motorboating would stop when I turned the "mic" input gain up a little.
After probing around a bit, looking for clues, finding red herrings I discovered there was a 12AX7 where a 12AY7 was supposed to be (preamp tube). The amp was modified/rebuilt a long time before we got it through a friend. The work looks solid, and kind of a hybrid of 5C3 and later designs. It also has an adjustable pot on the voltage divider where the lower half of the phase inverter gets its signal. I presume this trims the level for that polarity?
Postby greg on Fri Jun 14, 2019 5:13 pm
Soundfield Mk IV -
When the stereo outputs of the control box are connected to the Neotek Series II line inputs or insert returns (unbalanced inputs), there is a hum. This is not the case when terminated to the balanced inputs of the Pro Tools rig or tape machines.
This noise is present whether or not the mic is connected, and even with the unit off, power cable unplugged.
A couple of notes:
The outputs of the Soundfield control box are 'impedance balanced', so there should be no problem driving unbalanced inputs.
The way this is set up is the control box lives in the control room and connects to a dedicated Soundfield 12-pin socket mounted on the mic panel in the live room, via an 8-pair snake (mic cable extension). While listening to the hum (no mic connected), I disconnected the mic cable extension from the cont. box, and the hum went away. I then touched the shell of the connector to the cont. box chassis and the hum returned. Looking inside the connector, the shield-drain wire for the snake (surrounds all insulated pairs) was terminated to the shell. When I lifted it, and plugged the connector in, the hum was absent again. I suspect and will confirm later that the other end of this drain wire was similarly attached to the female panel mounted shell on the mic panel. Any noise or potential on that mic panel box + conduit could have a path back to this cont. box, and be heard for the following reasons...
Looking at the control box schematic, I saw that the safety ground for the IEC power connector was terminated to the main pcb, then sent through a 10 Ω resistor to the pcb's point of contact with the chassis. As far as I know, this is a big no-no. Simply having the safety ground travel through the pcb to the chassis is a problem on its own, much less through a resistor. What would be the utility of this?
The signal ground is also tied to the chassis via another 10 Ω resistor in parallel with a 100nF cap somewhere else on the main pcb.
Since the chassis could have noise current, via a ground loop (from the mic panel box/conduit other equipment 100s of feet away), antenna action (with the relatively long path to earth), or some other source, it could infest the signal ground? That noise would be transmitted common-mode when the outputs are terminated to a balanced load, so that might explain the silence there.
I have to admit I'm a bit turned around at the moment, and will look at it again later.
For now, I'm isolating the mic panel from the control box, eventually having the snake to it just be an extension of the mic cable electrically, with only one reference point for earth, the control box. The power safety ground is now attached to the chassis directly. Things are quiet.
Postby greg on Wed Jun 19, 2019 4:18 pm
Neotek Elite-
Aux Master module faceplate flexing too much.
Busted stud on the back of the faceplate.
Popped the pressed stud stump out, and replaced it with a new screw. Cleaned some connections while I was in there (related to the Cue source selection).
Other bits and nagging level tweaks to do to that module
Postby greg on Tue Jul 02, 2019 2:31 pm
Urei 1176LN (version H modified by Alactronics)-
Giant pops and noise when pluging anything into it.
Found 10-12 vdc on the input (XLR pins 2 and 3)! This 1176 uses the op amp differential input design working off a single 30v supply (amp inputs resting at 15v). The inputs to the amp are coupled via dc blocking capacitors with the connector side floating. One of the electrolytic coupling caps (film in parallel) was bulging and fell apart while I was removing it. I suspect they were leaking dc quite a bit. Replaced the electrolytic caps and added two drain resistors on the connector side (100kΩ) to keep things at 0 volts.
-Elsewhere-
Counterfeit Lomo 19a18 -
Intermittently working.
Cold solderjoint on the cable mic connector for the ground/shield conductors. The wires were loosely held in place by an insulator tube around the pin's solder cup. Checked all PSU voltages, replaced missing screws...
Postby greg on Fri Jul 05, 2019 5:12 pm
Testing on the Elite,
Making a new wire loom for the Neotek Series II power supply (moving it out of the control room soon).
Postby greg on Thu Jul 11, 2019 4:45 pm
Modding an Altec 436 to the EMI 124 idea.
Later :
Finished with the first one. Going to test it in action during a mix session this week. The "recovery" time options are slow, but not as bad as the original Altec. I might have to replace some noisy parts, but I just want the concept to be proved before burning more time on it.
Postby greg on Wed Jul 17, 2019 5:19 pm
Sennheiser MKH-405
We had this mic sitting around for a bit. Installed a little phantom to T12 converter inside a 3-pin din connector to XLR umbilical so we can use it without an external supply.
Users browsing this forum: No registered users and 10 guests
